By the looks of it that's you rear upper front suspension mount, and yes by the looks of it it's busted. grab the top a arm and wiggle it if you can see the hinge pin screw move or if the top a arm moves around it's toaste.It’s normal or broken...take for your help
Thanks mate ? still learning every day ? I've got the GPM one too. Does the job!Listen to Yas he knows his stuff. I got the gpm one and it fit perfect and hasn't broke yet.
Thanks just ordered ...now Waiting parts from honk kongDefinitely broken! Go for an aluminium replacement
https://customrcupgrades.com/product/arrma-6s-all-models-upper-front-hinge-pin-holder/
Or
https://www.gpmracing.com.hk/en/pro...RATON-6S-BLX-SPEED-MONSTER-TRUCK--ARA106040T1
Someone could you explain how change this part...manual or video ..tsk I’m advance marcelloDefinitely broken! Go for an aluminium replacement
Or
You have to take the hinge pins out and the top plate off. It's a bit of a pain, which is why when mine broke on my outcast, I replaced it with an alloy one. Think I got a voltage hobbies one a year or two ago when they were still cranking out parts.Someone could you explain how change this part...manual or video ..tsk I’m advance marcello
