- San Antonio TX
- Felony
- Granite
- Infraction
- Kraton 8S
- Mojave EXB
- Outcast 8s
- Typhon 6s
So I did a rebuild of all 3 diffs and after running my Outcast for the first time the center diff case was damaged bc the hex screws on the spur gear were rubbing against the motor mount. Got me a new center diff, changed out the bearings to the fast Eddies ones and now before I ran the vehicle again that's when I noticed what had happened with the original diff. I don't see why this is is happening. I even put a couple of shims behind the bearing that goes into the motor mount side. Any ideas why this is happening? I have a pic. I don't remember this problem with the stock bearings. I'm not sure if that has something to do with it or what. Thoughts?
I'm thinking that the stock motor mount assembly is garbage. This might fix my problem. Thoughts? :
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/382657951978
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/362109681681
