Hex Thread Type
RadioHacktive
Central PA
Anyone know if the thread on the 17mm hexes is considered fine or coarse? Safe to assume that the threading on the 17mm hexes for the 4s rigs (and 3s Typhon) is the same style that is on the 6s and 8s rigs as well?
Curious because I'd like use a closed wheel nut instead of the stock, open one.
ZooKeeper
Quack!
Chicagoland Burbs
  2. Granite Mega
  3. Infraction
  4. Kraton 8S
  5. Senton 3s
  6. Typhon 6s
Just from looks alone, I'd guess its a fine thread. Best way to check is to take the hex over to your local big box hardware store. Most - if not all- of them have a nut and bolt checker so you can test to see what size & thread your item is.
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
I think they are a fine thread as well. I have some Hot Racing hexes they are a different thread than the stock Arrma ones, the Hot Racing ones are bigger with less threads than the Arrma ones.
RadioHacktive
Central PA
Thank you both for your answers. I was leaning towards "fine" as well, but wanted a 2nd opinion.
@ZooKeeper That was something I didn't realize hardware stores did, but it makes sense. I'll take that into consideration in the future!
slick2500
Community Leader
Rapid City, SD
  1. Fireteam
  2. Kraton EXB
  3. Outcast 6s
  4. Senton 3s
  5. Typhon 3s
The thread pitch is 12 x 1.0
Yeah I found that too, when I was looking for light kits some titanium wheel hexes popped up under the "results matching fewer words" section on eBay and that is what it said in there.
