Supreme Arrma
I keep losing my pinion clip..Why< and any suggestions to keep it on??
It may be stressed past it’s opening limits. Next time it comes off, give it a squeeze with vice grips, etc, carefully. They make a tool for this but I’ve never tried it.
Is this for your Outcast? Perhaps your local shop has some.
You're right! I actually did that, and when I checked after a run the clip was gone and the pinion still in place.You don't really need it. It's only on there to capture the pinion if it becomes lose. If you used locktite on the pinion grub screw and let it set for 24 hours you'll be fine without it.
