depends how much you use it and where you use it. I don't have a set time but probably every 30 to 40 packs maybe I will strip the diffs on a brand new car though before I run it and put the diff oils I want in there also I make sure the diffs are shimmed correctly
You will do well. Lots of help here to cheer you on!!!
There is no rule to this, but I follow the 20-battery rule. Around that time, I break the entire rig down. Full maintenance
Tire bearings go fast on the 6S rigs. Between 3-5 runs, I remove the tires and hub bearings to clean or change.
Check the tires after each run to make sure no tire bead has broken
I blow it off after each run. I use Cow Moo Slick to spray all joints, suspension, and moving parts each run. Last, I spray the body and plastic with SC1 to keep the plastic up and shelf the RC
