bashingpumpkins
I’m curious to know whether it is better to run higher gearing or higher voltage for bashing and speed runs.
I think a lighter weight is better for bashing, so a 4s setup geared for 55-60 mph could potentially run at a lower temp than a heavier 6s setup geared for the same speed. There should also be less breakages with the lower weight. Let’s say the platform is a 6s Kraton.
Weight seems like less of a factor for speed runs, so the lower current draw of a 6s setup would be preferable to a 4s setup geared to reach the same speed. It seems like 8s should be better than 6s, but a lot of speed runners seem to stick with 6s on 8s capable motors/escs. Let’s say the platform is a limitless or infraction.
