- Brooksville, FL
- BigRock 4x4
- Kraton 6s
- Nero
- Outcast 6s
Asking 350 for all of it or scx10 trades
Selling my granite to get into crawling... here it is
Arrma granite with these upgrades:
BLX 185 esc
GPM f/r driveshafts
Savox waterproof servo
Kimbrough servo saver
Custom t2t brace
Full aluminum rod ends
Typhon 6S shocks
Typhon arms and turnbuckles
4S steel slipper assembly
18t pinion
4S rear body mount
Hot racing adjustable motor mount
Hot racing 17mm hex adapters
Pro-line mx28 badlands with removable hexes
T-bone f/r bumpers
Full sealed bearing kit
Gorilla taped body
Motor, diffs, driveshafts, chassis, body, all only have 1 short run on them.
Comes with these spares:
BRCC 3S body, chassis, driveshaft, and skid plate for full conversion.
1 front and 1 rear stock shocks
Full set aluminum shocks
Full set of yolks
Bumper skids
Spare servo
Full set granite rpm arms
1 front and 1 rear stock arms
1 HR motor mount
1 stock motor mount
Almost full steel slipper assembly (just need the screw)
Arrma 6S 2050kv motor
10k and 15k bottles diff fluid
Spare aluminum rod ends
Spare plastic rod ends
Motor mount holder
Battery tray blocks
A arm pins
A arm pin holders
Body posts
Front shock tower
Receiver box/servo mount
Battery mount velcro straps
14mm hexes
A few spare bearings
Diff case
Diff gasket
15t pinion
No remote no battery
Ships at buyers expense
BLX 185 esc
GPM f/r driveshafts
Custom t2t brace
Typhon 6S shocks
18t pinion
4S rear body mount
T-bone f/r bumpers
Gorilla taped body
Full set of yolks
Bumper skids
Spare servo
1 HR motor mount
1 stock motor mount
Motor mount holder
Battery tray blocks
A arm pins
A arm pin holders
Body posts
Front shock tower
14mm hexes
Diff case
Diff gasket
15t pinion
