Hobao Hyper MT Plus 2 Wobble
tensai
CA
Hello guys, I just recently got a Habao Hyper MT Plus 2. I ran it for the first time today in asphalt and every time I speed up and let go of the throttle the whole rear end wobbles. Any suggestion to a solution would help. Thanks in advance.
- Tensai
Hmmm.:unsure:
Does it have the Rear wheels Toe'd In??
Or are they Toe'd out?
Are you running a Gyro in this rig??
Any more info or even a Video would help much.:)
Hmmm.:unsure:
For sure will post vid as soon as I get home. Thanks
(y)
Which exact model is this Hobao, Was it a kit? or RTR?
I believe it has Tie Rods at the rear for rear toe in adjustments. Rear Wheels Toe'd OUT might be the issue?:unsure: Check this.
Toe the Rear wheels IN aprox. 2-3 degrees.
Waiting for a video to better help out.
Hi guys. Sorry for the late reply. So I've done more research and watch tons of vid. I've notice it's normal because of the big ol' tires. Did the best I can to some what mitigate the wobble. But really loving this truck. Tha ks for everyone's help!
You can actually fix this.
Adjust the rear toe in with the adjustable links
