- Points
- 983
- Wienerslider, Germany
- Infraction
- Kraton EXB
So I'm beginning to piece together my VTE. To recap the parts already installed, we have:
Scorched RC CF GT Chassis
Scorched RC Ti Spool
Scorched RC Ti Center Drive Shafts, Dog Bones & CVDs
Scorched RC Diff Lockers F/R
So this is what we're working with:
First up I installed a Futaba CB500 Servo.
Next up, I removed the electronics box from the original chassis. Upon inspection I noticed that the mounting screws have the same spacing as the servo mounting screws which made it a super simple install.
Unfortunately my 42T pinion was just a hair too big to fit so I completed the spool with a 39T Arrma gear. I put some small rubber shims in the diff cups to eliminate drive shaft movement.
For testing purposes, I've decided to install the Spektrum 4074 motor that came with my Infraction. This will change at a later date but for now I'm sure this will do just fine. Pinion is a 28T.
More to follow soon.
