- Points
- 723
- Maryland
- Infraction
- Limitless
- Mojave EXB
- Senton 3s
- Talion
- Typhon 3s
- Vendetta
I’d guess it is length. The mount is thicker
The pps mounts are same thickness, I have both arrma, hobao versions along with rotolok and iron man rc mounts.Unfortunately I can only compare an Arrma PPS with a Hobao Roto-Lok, so it's a bit of an apples to oranges comparison since the spacing of the two plates is different in the two cars. Seeing as the the motor mount ends 2-3mm to the side of the chassis holes and the Scorched motor mounting plate being slightly slimmer than the PPS (8.75mm and 10.94mm respectively) it would stand to reason that the Scorched mount should give you an extra 1mm to whatever the limiting factor is (be it steering bell crank in normal layout or the rear suspension arm when flipped) than the PPS mount. As for the cross dimension from left to right, the Roto-Lok is 73.57mm wide vs. the PPS at 70.56mm.
Are you saying my calipers be lyin'? lol...I kid. I might have pinched something somewhere by mistake. The same they are thenThe pps mounts are same thickness, I have both arrma, hobao versions along with rotolok and iron man rc mounts
Maybe I’m wrong I had both pps mounts sittin On my chassis, seeing if I could make the arrma one fit on the hobao.Are you saying my calipers be lyin'? lol...I kid. I might have pinched something somewhere by mistake. The same they are then![]()
The spacing from the motor plate to the diff support is wider in the Hobao. According to my calipers the actual motor mount part was a little slimmer on the Roto-Lok compared to the PPS, but I didn't measure the actual plate that gets screwed to the motor. I only measured the...."hoop-completion-half-circle-front-part" of the Roto-Lok. That may have been my error.Maybe I’m wrong I had both pps mounts sittin On my chassis, seeing if I could make the arrma one fit on the hobao.
I thought the mount itself was the same thickness as the hobao version.
The rotolok mount is definitely a couple mm thicker
Looking good, can't wait to see it when doneSo I'm beginning to piece together my VTE. To recap the parts already installed, we have:
Scorched RC CF GT Chassis
Scorched RC Ti Spool
Scorched RC Ti Center Drive Shafts, Dog Bones & CVDs
Scorched RC Diff Lockers F/R
So this is what we're working with:
First up I installed a Futaba CB500 Servo.
Next up, I removed the electronics box from the original chassis. Upon inspection I noticed that the mounting screws have the same spacing as the servo mounting screws which made it a super simple install.
Unfortunately my 42T pinion was just a hair too big to fit so I completed the spool with a 39T Arrma gear. I put some small rubber shims in the diff cups to eliminate drive shaft movement.
For testing purposes, I've decided to install the Spektrum 4074 motor that came with my Infraction. This will change at a later date but for now I'm sure this will do just fine. Pinion is a 28T.
More to follow soon.
Thanks bruvLooking good, can't wait to see it when done
Man, I scantly thought it possible that I could like something more than the PPS motor mount. I'm all about the thing. The Roto-Lok though...it might do it. It's such an ingenious design and due to the way the motor is rotated off-center of the mounting plate to set mesh, you have the option of engaging mesh from two sides. I actually don't think that this was intentional or a design consideration but it does have some interesting consequences. You can either rotate the motor CCW so that the pinion engages coming from underneath or rotate the motor CW to engage coming from the top. What is the interesting consequence you may ask...well, the usefulness will depend in part on the size of the gears you're using and whatnot but, if you rotate the motor so that it comes over the top, this actually give you a lot of clearance under the motor and could, potentially, make it possible to fit longer motors as there's a chance that you'll clear the suspension arm/hinge pin area of the car.Absolutely killer build. So, you really like that Roto-Lok, huh? I’m going to measure the length of motor I can squeeze in there when I start that full length build. It occurred to me that the wheelbase of that one is 328mm and not 325mm. If I even split the difference and only pick up 1.5mm to the front I may be able to do it. I’m wrapping up that first build as we speak and then I’ll get on it. Still been a little tapped for time since the holidays, but should be opening up again after this weekend.
I hope this makes sense. If not, let me know and I'll snap a few pics to illustrate what I mean.
Yes. The outside half ring is held on with two screws. The bottom one you just leave cranked down and loosening the top screw slightly is enough to be able to rotate the motor plate.I really have not seen the mount move around freely, but was thinking about that the other day for the reasons you explained.
What holds the rotation still? It just pinches it tightly with the outer clamp?
It looks to be a very solid device.
No man, that makes absolutely perfect sense. I just fit the new 5670 on the original (flipped mount) build and it fits with no clearance. Like, friction fit. I’d have to relieve the left steering bellcrank post a 1mm to do it, but I can certainly do that. Very curious to put the motor mount on that Scorched full length chassis after the bellcrank is fit and see where it sits.Man, I scantly thought it possible that I could like something more than the PPS motor mount. I'm all about the thing. The Roto-Lok though...it might do it. It's such an ingenious design and due to the way the motor is rotated off-center of the mounting plate to set mesh, you have the option of engaging mesh from two sides. I actually don't think that this was intentional or a design consideration but it does have some interesting consequences. You can either rotate the motor CCW so that the pinion engages coming from underneath or rotate the motor CW to engage coming from the top. What is the interesting consequence you may ask...well, the usefulness will depend in part on the size of the gears you're using and whatnot but, if you rotate the motor so that it comes over the top, this actually give you a lot of clearance under the motor and could, potentially, make it possible to fit longer motors as there's a chance that you'll clear the suspension arm/hinge pin area of the car.
I absolutely think that the Roto-Lok will solve your interference issue with the rear hinge block. I took a few quick pics to show you what's possible. So first off, under normal circumstances, I wouldn't even be able to fit a 4070 into the VTE. While it's a bit tight where the leads come out of the back of the can, with the Roto-Lok I was able to successfully mount my 4080...albeit with some caveats. Here's a view from the side and underneath the motor:No man, that makes absolutely perfect sense. I just fit the new 5670 on the original (flipped mount) build and it fits with no clearance. Like, friction fit. I’d have to relieve the left steering bellcrank post a 1mm to do it, but I can certainly do that. Very curious to put the motor mount on that Scorched full length chassis after the bellcrank is fit and see where it sits.
One reason I originally wanted to flip the mount was because I couldn’t fit a 102mm can due to interference on the rear inner hinge block. Maybe the Roto-Lok could raise it a couple mm and alleviate the problem.
