SrC
RC is a lifestyle choice
Hospitality Award
- Queens, NYC
- Fireteam
- Infraction
- Limitless
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Typhon TLR
When you say discharge. Discharging from full charge to Storage 3.8 volts? Or are you discharging all the way down to a fully discharged lipo? Discharging from a topped off charged pack down to 3.8 v per cell will take a long time. My 6S 6000mah will take approx 3 plus hours the charger times out at 3 hours as I set it to do so. I will usually reset discharge Storage mode and after about 45 min it is discharged to 3.8.
This charger discharges very slowly as designed to do. It will throttle down the discharge rate as it gets close to its target voltage. It does this to balance the cells better as it approaches the target volt.
