Hobbywing 3.175 - mod1 gear - why am I having issues finding a pinion?
utvbroz
Hey everyone, I purchased a hobbywing motor with a 3.175 shaft diameter.
The spur on my Tekno sct is mod1, but having issues finding a pinion mod1 3.175 gear.
Anyone run into this? Am I going to have to switch the spur out to a different pitch to get a pinion? If so any recommendations ?
Appreciate greatly in advance!
Yeah I bet some options are out there but it might be tough to find them. Most mod 1 pinions will have a 5mm shaft.
Another option is to buy a sleeve. Some pinion sets even come with a sleeve.
Acekeeps Steel 3.175mm (1/8 inch) to 5mm Pinion Reducer Sleeve for Converting RC Motor Pinion Gears, Set of 3 https://a.co/d/1lRZcTz
Yeah i'd just pick up a reducer sleeve like dure16 suggested.
There are also many pinion sets out there that come with a reducer sleeve too:
https://www.amazon.com/HOPLEX-Hardened-3-175mm-Coupler-Monster/dp/B092PYFTLW/
Just as an example, haven't used that one personally.
I know i had similar problems with my HPI bullet, mod 1 gearing, but stock motor is 3mm shaft. I eventually solved the problem by updating to a 5mm shaft motor so I didn't have to tiptoe around around gearing issues.
