Typhon2016
Yup same thing I ran into =(I was just browsing the web for answers. There's rotors for other hobbywing motors but yet to find anything for this motor...
Really the only ones that I have readily seen parts and parts lists available for are Tekin motors, which I have started buying more often because of this. Like you said though, I know that it used to be the thing to do for all brushless motors. Sadly, they are all pretty much just disposable electronics now.Yup same thing I ran into =(
It used to be a thing to make rebuild kits for brushless motors that came with a new rotor, new bearings, spacers and sometimes even screws. But with all these Chinese motors now I think they decided that it wasn't worth it to do that anymore.
I know this is old, but I broke the shaft clean off my 4985, if I could find a similar length shaft, and keep the magnets in place, but doubtful. I too have tekin t8s, and thankful that after the initial investment, tekin products long term are not that expensive to rebuild, or even replace.Really the only ones that I have readily seen parts and parts lists available for are Tekin motors, which I have started buying more often because of this. Like you said though, I know that it used to be the thing to do for all brushless motors. Sadly, they are all pretty much just disposable electronics now.
It's Kevlar. It isn't worth your time trying to fix. Just buy a new motor. https://www.ebay.com/itm/393024970393?hash=item5b821d1e99:g:1kcAAOSw4h1fuDMgI hat a similar issue today. The motor smelled and was turning hard. Opened it up and found pieces of the stripped isolation inside the motor, which were causing the hard turning an smell. Otherwise mechanically the motor seems fine. Hence the question.
I would think if the isolation somehow would get replaced, the motor should work fine again? If so, what should I substitute the isolation with? Guess it needs to be something heat resistant. The original insulation seems to be something from glas fiber?
