I agree with the tire comment. The diffs so far have been holding up really well. HR steering hubs are a must in my view for this upgrade the weight and speed the plastic would give to much and with the 4965 we aren’t trying to keep the rig light. Great upgrade for the money and so far really happen with it. The max6 fan is weak, but everyone already knew that.The Max6 4985 combo is noticeably more powerful than the BLX system, and the delivery is smoother throughout the entire throttle range. I have had it in both my Outcast and V3 Talion and the diffs hold up well to the abuse I've put them through. Tires on the other hand have been struggling to stay glued to the wheel, but that's more of a gearing decision on my behalf. Once you gear for the upper 70's to low 80s (mph) range and start hitting long stretches of wide open throttle, the tires will inevitably start to come unglued. As long as you stay on top of tire maintenance in between packs and reglue when needed it's manageable.
View attachment 45718View attachment 45719
What packs do you run in the outcast with that? Did you notice run time changing a lot from stock or did you ever run stock long enough to have an idea?I've been beating on this system since April and haven't had any issues with hubs or any plastic parts yet. Then again I only added 1.15lbs over the stock weight with all the upgrades (m2c/hr braces/bumpers/skid plates/ GPS, etc) and tried to keep weight in mind throughout the build.
Talion geared 22/46 & Outcast 20/50
I run Powerhobby 6s 5200mah 75c packs and didn't notice much a difference in run time over the BLX systemWhat packs do you run in the outcast with that? Did you notice run time changing a lot from stock or did you ever run stock long enough to have an idea?
That's awesome and crazy at the same time. So much more capable, but doesn't consume more power.I run Powerhobby 6s 5200mah 75c packs and didn't notice much a difference in run time over the BLX system
tires are the limiting factor in the Outcast with this system ?That's awesome and crazy at the same time. So much more capable, but doesn't consume more power.
I'm still pretty content with the stock stuff in my outcast, but good to know if I really want to run a 15T speeds vs 13T to avoid overheating... I have options. Will be like $250 to pick up 5-8 mph. I know I can go higher with that setup, but I don't need it... need... such a strange phrase to use with this hobby. lol!
nice set up. how did you mount the dual fans - who makes those?The Max6 4985 combo is noticeably more powerful than the BLX system, and the delivery is smoother throughout the entire throttle range. I have had it in both my Outcast and V3 Talion and the diffs hold up well to the abuse I've put them through. Tires on the other hand have been struggling to stay glued to the wheel, but that's more of a gearing decision on my behalf. Once you gear for the upper 70's to low 80s (mph) range and start hitting long stretches of wide open throttle, the tires will inevitably start to come unglued. As long as you stay on top of tire maintenance in between packs and reglue when needed it's manageable.
That motor mount is my by @Mr.Duke ??nice set up. how did you mount the dual fans - who makes those?
Haha. Ok cool - now you have me thinking about purchasing a CAD/CNC. I knew this hobby would start to cost me! ?
In the meantime I’m using Yeah Racing dual fan on my BLX set up- and it’s been working quite well - very noticeable temp drop. But still looking for a good fan for when I switch to the MAX6 combo..
No need for expensive cnc. If you have space and are patient, great used manual machine tools can be had for very cheap. Hardest/expensive part is moving them. Bridgeport mill, swivel vise, band saw and some time you can make nearly anything for and rc car.Haha. Ok cool - now you have me thinking about purchasing a CAD/CNC. I knew this hobby would start to cost me! ?
Hey mate I have a talion also with this combo. How did you fit the motor im having trouble with the diameter. Tossing up whether to grind down the fins on the engine or put shims under the motor bracket.The Max6 4985 combo is noticeably more powerful than the BLX system, and the delivery is smoother throughout the entire throttle range. I have had it in both my Outcast and V3 Talion and the diffs hold up well to the abuse I've put them through. Tires on the other hand have been struggling to stay glued to the wheel, but that's more of a gearing decision on my behalf. Once you gear for the upper 70's to low 80s (mph) range and start hitting long stretches of wide open throttle, the tires will inevitably start to come unglued. As long as you stay on top of tire maintenance in between packs and reglue when needed it's manageable.
Do you have an older talion with a non sliding mount. The newer v4 mount fits this motor no problem. You can find them for around 20$. Don’t grind on the motor.Hey mate I have a talion also with this combo. How did you fit the motor im having trouble with the diameter. Tossing up whether to grind down the fins on the engine or put shims under the motor bracket.
Yeah older one I saw someone shimmed theirs so I did that for now. I will order the engine mount tonight. That motor is ridiculous brand new pre glued tyres just got ripped clean off ? pre drilled bandlands. Using an 18t pinion till my fans arrive.Do you have an older talion with a non sliding mount. The newer v4 mount fits this motor no problem. You can find them for around 20$. Don’t grind on the motor.
https://jennysrc.com/collections/ar...-motor-sliding-outcast-kraton-typhon-ar106048
