I'm in northern Illinois. Worth a try from AliExpress so I ordered that one. Dang thing came loose, flopped out of the chassis and got chewed down nothing on the switch side. Spliced it back together so it powers on with the battery plugged in but I'd prefer not to leave it that way, plus I can't program anything now. Thanks for the link.I don't know where you are but if you order on Ali express which I know is overseas, usually takes about two weeks
https://www.aliexpress.com/item/33037902419.html?spm=a2g0o.productlist.0.0.557a22d2bXObTV&algo_pvid=35d54865-2f26-483d-b7e6-0010dd014108&algo_exp_id=35d54865-2f26-483d-b7e6-0010dd014108-0&pdp_ext_f={"sku_id":"12000021441651929"}&pdp_npi=2@dis!USD!!7.05!!!!!@2101d68d16525708981855791e2d36!12000021441651929!sea
i have ordered from this seller many times
Would a spektrum power button work ?Looking for a replacement power button for a max6. I believe the max5 is the same so either will work. Only source I've found is overseas from ebay at about 2 months out. Was hoping for one a little sooner.
The HW program card is only like $10plus I can't program anything now.
