Bananus
- Typhon 6s
I shouldn't work on stuff at 1am...
Thanks! I see that you are running the stock motor, I imagine that it runs fine on 6s? The reason I go for the max6 is so it stays cooler (or I hope so) during long running and summer heat. I doubt that I will go on 8s as I’m scared to break the driveline.I think the space is different on the talion, things are moved around a bit, but I think it's the same on the kraton, just more room from the motor mount on back. The outcast and typhon use the same chassis I believe and I just put a max6 in my outcast. I screwed up and mounted the esc too close to the servo, then ground down some of the servo mount (about 3mm) to have a hair of clearance. I shouldn't work on stuff at 1am...
