That's is not what he asked.
From what I have read - the 2200 you asked about can overheat on a monster truck.
It should be fine on a Typhon.
What are your goals for switching to this? If you just want a stock replacement- fine. If wanting to upgrade- I have a better idea, just let me know.
do you run it on 4s and can you run on 6s?I run a MMX with the Castle 1515-2200kv motor in my Typhon. Works very well. It was no good in my Kraton as it would thermal constantly.
What do you run yours in? The typhon or something else?
Here it is in what was born a notorious. SWB CHASSIS. Not much room between max6 & pinion gear lolGood to know. Might be worth trying in my outcast on 6S then. Won't fit in my ERBEv2, not enough room for anything over 74mm.
