Hi guys.
So, I decided to up the Power in my BRCC 4x4 3S (Well, the mix that the car is at the moment...it is running on Typhon Arms and SCT tires; and yes, that is a E-Revo body on there).
This thing is getting a TP Power TP4030 Motor (40 x 63mm Motor ; 3267kv) and a Hobbywing Max8 ESC. It will run a 26 tooth pinion (if it won't run too hot), will only be run on 3S Lipos and, as I know myself, on the highest punch setting.
So here is the question, would you solder the included cappack to the esc, or is it just dead weight as the car is pretty light, the motor is not the biggest can ever and it will only be run on 3S? Looking forward to hearing your guys opinions.
