- Fireteam
- Typhon 6s
https://www.amazon.com/HOBBYWING-Ezrun-MAX8-Combo-4278SD
If I understand the reviewer correctly, they were told by Hobbywing that using a battery without a high c rating can cause a fire?
it does require you to use higher c rating batteries to operate, if you don’t upgrade to these batteries unfortunately you will have issues, over heat stop working or worse like my first one catch fire! They did replace it under warranty but did note to me to change my batteries.
