Lbizzle
The problem is when I hit a jump it dies... like no power to the motor at all so I can’t correct it mid flight. It lands and wreck most of the time now. So I experimented and it does the same thing if you just drop the car on it wheels from 4 feet of the ground but you can still steer it just lose power to the motor. If you wait 15-30 second it returns to normal all the wires are tight no loose connection any where. You can drive it all day as long at you don’t hit anything even the slight bump with shut it down but every time you still can steer. So any idea what’s the problem is????
