I need someone, smarter than me to give me some feedback and on this forum it's just about everyone.
I've got a battery tray figured out where I can mount two large batteries side by side, but as I get in to there are some complications. Nothing at little duct tape can't fix. It barely fits under the body.
But while I was looking a this I had a different thought and I'm back to thinking about putting it next to the servo and moving the receiver/receiver box to the center brace or possibly under the nose cone.
My idea is to chop the "electronic module set" and get one flat-ish surface. cut on the red lines below. This is a stock photo. I can shim it up with some ABS or if I use Dual-Lock it will make up any height differences. I would leave the servo mount intact.
Or just get/make a different mount. There is one from Arrma (and ebay), but I'm not sure how the actually mount to the chassis.
I mocked this up (nothing is attached) and it looks like it might work. The nub'ins on the side are a bit close, but nothing some shims can't fix. Yeah the ESC is a bit crooked here. The servo seems to clear if it's close to the brace. In the stock location it's pretty close and may not work, but I might be able to move the arm and servo up?
Question 1: Does anyone know how this, or similar, servo mount attaches to the Limitless chassis? Although it looks a bit beefy to fit where I need it.
It uses a "base plate" but I'm not sure the holes line up with the existing ones.
Would I need to drill new holes?
Question 2: Any thoughts on making a mount and attach it to the support brace?
Something simple like this from a Redcat would work.
Other thoughts?
Other thoughts?
