Senton Hoons on 3s/6s Senton
People have put goons on 6s platform, I think they will work with 3s
You will need 17mm hexes to use Hoons on any of the 3S and Mega vehicles. Typhons already come with 17mm hexes.
Do I need Typhon arms? Do the hoons clear the steering block with the normal arms?
The arm length doesn't affect hub clearance for the wheels since it's the same hub.. but if you mean will it rub at full left/right on stock arms it shouldn't. However since the Hoons are zero offset you might want to try the Typhon arms for the extra width so the tires aren't all tucked really far under the body.
They do if you use the hot racing 17mm hub extenders. I am not sure if you're using the typhon 17mm setup. The hoons are pretty roomyon the back so I assume they probably would.
