I got my hot racing shock bodies and started to assemble them everything went fine at first in my first shock but the bleeder valve was leaking making air to form inside the shock so i had to take it apart again and tighten the bleeder valve harder. And i still have air inside after bleeding everything up ?What a pain in the ass also the collar for the spring is not metal but metal painted plastic and reakly cheap one
but after im done bleeding them correctly im oretty sure they are going to be amazing
Its my first shocks who has a bleeder valve so in my mind there should be 0 air inside. And what the bleeder valve relies on to seal everything is a dam plastic spacer who compresses quite a bit when i make the screw rly snug. If someone has the part numbers for the orings and other spares for the shock bodies please let me know
