- Thread starter
- #21
Well was not able to remove the oil quickly i had to press really hard even the shaft started to leak oil at that point.. a shock vaccum how much that costs? I lost a bit of shock tarver and my stock oil tune in the rear is so hard and low reboundI use a shock pump to vacuum out any air. At Full compression there shouldn't be any air within the shock body of a bladder type setup. Air is above the bladder and separate from the fluid. Emulsion shocks work with a preestablish volume of air above the fluid.. In a perfect world....
Also, Why do you remove the bladder? You like emulsion?
