Ragga
Hi Fam,
Installed the hot racing bell crank with the hot racing servo saver and a new 25k servo.
After installing the HR bell crank, the screw on the servo arm is hitting the chassis and not allowing full movement. Has anybody had that problem?
I had to reinstall the original big rock bell crank and everything works correctly.
Any suggestions on why would the servo arm screw keep hitting the chassis with the hot racing bell crank installed?
Do I need some kind of spacer somewhere to make the servo sit higher? Or do I need a flat screw instead of the rounded raised one that goes into the servo arm? Or am I doing something wrong? Watched videos and nobody else had that problem.
Thank you.
Thank you.
