Kraton Hot racing diff gears
Kaden1308
I messed up the gears in my diff so I was looking for some new ones and I was wondering are them stronger than stock and if anyone has them are the good?
Engineer
Don’t let the magic smoke out.
Ohio
  1. Voltage
What got messed up - was it gears or pins? How was the diff shimmed internally? Where the diffs properly filled with fluid? What kind of power are you running (motor)?
For the most part stock gears are fine but diffs that aren't shimmed correctly or are under-filled with diff fluid may fail prematurely.
Massachusetts USA 🇺🇸
  1. Limitless
  2. Kraton EXB
  3. Typhon 3s
  4. Typhon 6s
+1^^^
lots of factors, there’s people going over 100mph or 30feet in the air on stock gears. So they are pretty strong depends on how there used of course, being sure to setup everything is a challenge but necessary cause the factory misses some things now and then. So going through the new equipment is a pita but worth it.
slick2500
Community Leader
Rapid City, SD
  1. Kraton EXB
  2. Outcast 6s
  3. Senton 3s
  4. Typhon 3s
Unless they made the gears bigger with bigger teeth, which isn't really possible, they will be no better than the stock ones.
