AimlessRC
- Granite
I've seen these things since I've been searching for hop-ups... $3.88 a piece (BLX needs 3), and they replace the 3 tabbed fiber clutch pads in the slipper within the spur gear.
I'm thinking of giving these things a whirl. Dissipate heat better, less noise, more positive engagement, all that good stuff.
Has anyone actually tried them out?
I popped my slipper apart today during a maintenance check (2019 Granite 4x4 BLX 3S) and noticed a lot of black gunk building up on the slipper plates. This is after a couple weeks of hard use, slipper set to 2 turns out from softly tightened on both 2S and 3S (12 packs give or take). It almost looks like smear from the aluminum pressure plates mixed with any sort of dust that would enter though the bottom of the spur housing... potentially has some assembly grease or lube from the bearings wandering up in there. Also, between the two plates (where they meet on the brass bushing) there was a LOT of gunk in there.
It's near impossible to get the gunk off of the plates unless I sand it down with some 800g wet sandpaper on a piece of glass with a block ontop of it. Which I did to one of them (the center one)... the other two I just flipped around for now.
