Kraton Hot racing hubs.
Cereal_killer
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
So after all the parts I've scored locally and a few online. I decided to upgrade to the hr hubs. But something seems way off the hub hex were the wheels set seems a little farther out rather than using the plastic hubs. Am I doing something wrong? Or does the hr give it a little wider spacing?
You ordered the ones for the V1 Kraton, Typhon and Talion.
You need these https://hot-racing.com/?partnumber=AON21M01;c=926
This is one of the bad things about Arrma changing their models every year you have to pay close attention to what parts you are buying.
Odd it says kraton or typhon. They have different length axles...weird.
Those look like they have the extension for the longer axles!!
V1 Kraton had the same hubs and stub axles as the Talion and Typhon. V2-current they are wider.
These are the ones you got https://hot-racing.com/?partnumber=AON21MA01;c=926
Replaces Arrma AR330187 front steering blocks
- Replacement parts include, Hot Racing: AON21G (CF arms), AON21N02 (hub nuts)
- Known to fit the following Arrma vehicle part numbers. The vehicle part number can be found on Arrma's website, the literature that came with the vehicle, or on the vehicle box around the barcode. If a vehicle is marked below with the word "optional, " then the part may fit, but may require some modification.
- Infraction: ARA109001
- Limitless: ARA109011
- Mojave ARA106058T1, ARA106058T2
- Kraton: AR106005
- Senton: AR106007, AR102654, AR102673
- Talion: AR106003, AR106014, AR106030 (2018 V3 model), ARA106048 (V4)
- Typhon: AR106001, AR106013, AR106028, ARA106046
description revised by: SN May 6, 2019
AR106005 https://www.arrma-rc.com/rc-cars/2014/kraton/blx/ I didn't know the first Kraton came with the ATX100 radio.
I'm going to attempt to take em back and show them that it wasn't the right set. Very much appreciated it 👍
I mean in their defense it does say Kraton on it 🤷‍♂️
I would say maybe once every 2-3 months I'll see someone post about this.
True. I guess I can get shorter cvd if all else fails. It should either even the front out to the rear. Or just shim it out and leave it wider?
If you use shims/spacers, it will put a lot more stress on the outer hub bearing.
The shorter CVD axles will cost you $20 anyways....almost 1/2 the cost of the correct hubs.
