Yeah but it lasted 1 month before the rear was about to failWhat am I looking at here? All I see is a worn input/pinion gear.
I want to know how dude
That’s a good bit of info ??Aparabtly if you run a 15t pinion on the stock motor mount you can add a third screw to eliminate the chance of bending it
You landed on what were you using s bumper when you shadered the front end?That’s a good bit of info ??
Where do you add the screw..?? You have a pic..?
That’s good info. I never tried to use a third screw but it makes sense to me. Good find?? Hope it fixes your mount issues.View attachment 53250
I might know why the stock motor mounts could be stronger if you see carefully the stock mount comes with the pinion 13. And is you look at where the two screws align it makes it pretty hard to bend the dam thing vs two one in a streight line on the adjustable one. Im going to get new screws and go back to stock i remember it took a lot to bend my stock motor mount the first time i remember landing on the nose and stuff until i hode a drain thing full speed and my car was bassicly motionless because the gears crushed each other
If I recall, the BLX mount is new. It isn’t the same as the Mega mount. Am I wrong?I forget where mine bent, but wasn’t it more like at the waistline (view it like a woman’s body, the skinniest part vertically) in the motor mount? Personally I think the problem is that the motor is too heavy for the stock motor mount. It was designed for a much lighter brushed motor but they kept sticking a heavier (3S) and heavier (4S!) motor on it but didn’t redesign the part.
Made billed vs casted but still bends like stickIf I recall, the BLX mount is new. It isn’t the same as the Mega mount. Am I wrong?
Maybe they are contracting Mitch to make some good ones ???Made billed vs casted but still bends like stick
If the blx one is the same as the hot racing one i have one in backorder from arrma but it keeps getting delayed september november now december its ridiculous
Yeah but honestly i wont buy a 130$more expensive rig(more than 130 might lose 150$ in the resell of the kraton) just because of a motor mount. Sure it sucks but i will get something bigger a 6s rig because i realise that i want more than what my 4s kraton can give meMaxx, oh Maxx Maxx Maxx, did I say MAXX?
The blx mount is unavailable here they keep telling me they going to get them in the next release but kreps getting delayed?. I once got the mega version without knowimg and lost my money againI think this is why the HR mount bends, there is less metal where it bends..!!
Having the bolt holes recessed loses metal and therefore strength...
I still hope M2C make one soon, maybe my petition might help..??
https://www.arrmaforum.com/threads/m2c-racing-petition-for-3s-4s-motor-mount.15729/
If M2C made one, I think its about 6-7mm thick, because of its small size I believe it would be nearly unbendable..??
View attachment 53369View attachment 53368
Some of my bends, these are all the HR mount...???
View attachment 53370View attachment 53371View attachment 53372
