(1) Balance mode shows no timer movement,charge shows timer movement. Should I use charge or balance mode?
(2) What are you using for a DC power supply?
1. Balancing only balances the cells at whatever level they are and until they are done, no timer needed. There is a safety timer limit but not shown.
No, I never use the balancing function, useless imho. Storage and normal charge will balance the cells anyway.
2. 99% of my use is on AC. I use a DIY supply, but you would need some electrical experience for wiring.
https://www.amazon.com/gp/product/B0786LMNR2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Use normal charge mode and when the screen turns blue (from yellow first... then to green... then to blue (I think these are the colors)) and starts beeping regularly every minute or so, it will be balanced.So just use Charge and it be done with it? I thought I read somewhere that it will auto balance after charge anyways.
I saw some posts for taking two power supplies( HP I think) and making one big one. I'm always messing with stuff like that,so it wouldn't be a big deal. Notice a big difference in charge times between ac and dc?
Yes,I Charge at 1c also.No, there is no difference in charge time as I always charge at 1C rate i.e. gain is nothing
If you go higher in charge rate you decrease charge time but lipo's have a shorter life. I guess you could go up to 2C and charge time would go from ~ 50 min down to 30min. I'm not in a rush where 20min makes a difference. You could charge batteries in parallel i.e. more batteries, that is where a time benefit would come in handy as you have more power available.
You will notice that at the end of the charge cycle the 'Amps' will go down and will be fluctuating, that is the balancing.
All chargers will balance the pack at storage level or at full charge level. Has been the default for a while.
Extra balancing will make you feel better but does nothing from a technical viewpoint. Some chargers have a 'balancing' mode, mainly because people are looking for it based on limited knowledge i.e. 'balancing is good' and are looking for this buzzword.
Not trying to make you feel bad, this is a clever marketing trick based on some truth. I learned as well, just some time ago.
Balancing mode makes sense if you do not want to complete a specific mode i.e. full charge. Still takes longer than finishing and I never understood that logic myself.
Historically with rough timeline based on my own memory.
The early Lipo chargers just shut off at a specific voltage (208?) just like NiMH chargers.
2009 - external balancer's came around when people discovered the disadvantages of unbalanced packs under load
2010 - chargers added this as a 'balance mode'
2012 - balancing became a part of the standard charge cycle
- fast forward to 2020 - old SW code is copied and people will not buy a charger unless they have a balance mode
Don't hold me to those dates, I'm probably way off but the technology evolution is spot on.
If you can charge your current lipo's at 1c i wouldn't bother for a dc psu. If you need more watts you could.Yes,I Charge at 1c also.
My maximum charge need is 4x 5000mAh 6s at 1c. For that i use 2 Hota's D6 Dual and 1 HP 12v 750watt 60amp psu which is sufficient.
To max out the chargers i would need a 24v psu (or double 12v), but there's no need for it.
With your detail, I'll have to go ahead and do it. I'm always scaredy to update firmware on stuff like this (no easy contact, service, language barrier potential) but I guess I can give it a rip.Just because I updated firmware again as it's now at 1.0.11. No idea what changed but was curious if I can repeat my update success. Spoiler: No idea what has changed, yes it works.
Steps for a successful upgrade:
1. Download firmware, pick the right one
http://www.hota-exp.com/index.php/service_l_2.html
2. Rename the file, add a .zip as the extension. File is now recognized by windows
3. , Right click and 'extract' make sure you know the location (or doubleclick)
4. Three files inside, the executable (HTLoader), the firmware (D6+ V1.0.11.prg) and the instructions
4a. Read the instructions and try not to smile, I copied them at the bottom
5. Get your charger but DO NOT plug it in
6. connect a USB cable from your PC/Laptop to the back of the D6+
--Still not plugged into power--
7. Start the executable (HTLoader) and it will start up
8. in the software, use 'Open' and open the firmware file
You have ~ 5s for the next 2 steps, simple but be aware
9. hold the 'CH' button on the charger and plug it in; the charger will beep
10. release CH button and click 'Update' in the firmware loader
11. Let it finish programming ~ 30s
Done.
You can disconnect and cycle power and use it again. If you had any custom settings under the system menu (hold CH and OK for 3 s) I'd check them again.
Hota instructions:
- First download the new firmware from our website to your PC and install it,
- then open the software update tools ; link the charger to your PC through USB string ,
- turn on the power of the charger , and listen to the "bibi" sound ; click "update " before those "bibi" sounds stop and try it
sorry yes A...ok, only once i was trying on 10AI believe you mean charge current. For a 5000mAh battery you should charge at 5A, not 10A.
m=milli=1/1000
The way to determine, capacity 5000mA/1000 = 5A
Some batteries can take 2x (10A), 3 or 4x the standard rate, it will reduce life if they are not capable.
thanks for your explanation ? i would just like to know the storage mode program... today i put the battery on the storage mode setting which is 3.80 per cell ... and it took almost 2 hours to finish ? can i set in storage mode also 5A? or maybe I don't use the storage function, just normally charge up to 3.80 per cell and then interrupt the charging process, because if that means you reach storage mode this way, it's much faster ?No 5A is fine, the 'standard' charge rate for any Lipo is '1C' which is capacity/hours = 5000mAh/h = 5000mA; the 'm' is used for marketing and confuse people with metric stuff 1m =1/1000
Charging your Lipo at 10A (2C), just once, didn't do any noticeable damage. Your Lipo might even be capable of this without damage, just not recommended.
Always take the advertised capacity and divide by 1000, that is the 'Amp' setting you should use.
@Knxwledge no this time they were empty...in the settings I chose storage charge at 1A, it took a long time, almost as long as the discharge ... it filled them up to 3.80 ?We’re the battery fully charged when you did storage mode?
If that’s the case, the charger would have to discharge it first which would take very long because most charger can only discharge at a certain watts. I think the Hota is capable of either 15 or 30 watts which isn’t a lot. Don’t quote me on that.
a separate discharger would make it faster or just use up all your battery with your rc then do storage charge after that
