no1zeppelinfan
How do I assign a button on a Spektrum DX5 Rugged for lights? I tried on the "Aux assign" and the lights are on aux 1 but not turning them on and off. Anyone know? tia
You need to buy a light controller https://www.amazon.com/dp/B08FLZXSD...abc_W220Y0V2FYCD4B8TMEPD?_encoding=UTF8&psc=1How do I assign a button on a Spektrum DX5 Rugged for lights? I tried on the "Aux assign" and the lights are on aux 1 but not turning them on and off. Anyone know? tia
Sort of lost patience with it. Couldn't find info on how to wire up properly.Did you ever figure it out? I got my control modual yesterday and hooked it up this morning, works just fine. I just plugged it into my rx plugged the red and black wires directaly into the control modual and started playing with the differant settings on mine. Solid, flashing, fade, fade while flashing and dim.
Thanks mate, will do it in the morning and let you know, thanks so muchok it looks plugged into the rx correct, the littlie modual has 4 pins right, 2 are marked + 2 are marked -, the lights have red and black wires + - you don't need that y connecter
One quick question, does the other end of the 4 pin lead go into the receiver?ok it looks plugged into the rx correct, the littlie modual has 4 pins right, 2 are marked + 2 are marked -, the lights have red and black wires + - you don't need that y connecter
