Buy an air compressor with say 6 litre tank to keep cost down and use soon after as you can as moist mud will blow off. If you leave and mud dries totally, much harder. Great investment, how every rc owner does not have one is beyond me. Silicon spray is good once cleaned around drive shaft areas etc. Spray and leave an hour then air blow off residue. Simon. Uk.I did some bashing on some loose gravel and it started raining. How do I clean the body and components? Tires? Undercarriage? Suspension?
I've seen some people just spray it down with a hose. Is that okay or should I be cautious?
Spend more time drying your car than washing it. Any water left will rust your screws and fasteners and there goes your great looking chassis. Carefully warm air dry your hardware if you can. WD 40 is good to use. WD stands for Water. Displacement. Lots of people think WD 40. is just a lubricant but it's a lot more, in fact, you can buy WD. 40 with silicone oil in it. Protect your electronics from moisture, takes just a few extra minutes of care while you are cleaning. Preventative maintenance is important with RC cars.Hose is fine. don't use high pressure and don't submerge the entire thing. Hit with air compressor after if you have one.
Agreed, avoid cleaning with a hose pipe... eh ? I'd never do this... asking for trouble, it's an rc car with electronics and a battery. They don't go together.Spend more time drying your car than washing it. Any water left will rust your screws and fasteners and there goes your great looking chassis. Carefully warm air dry your hardware if you can. WD 40 is good to use. WD stands for Water. Displacement. Lots of people think WD 40. is just a lubricant but it's a lot more, in fact, you can buy WD. 40 with silicone oil in it. Protect your electronics from moisture, takes just a few extra minutes of care while you are cleaning. Preventative maintenance is important with RC cars.
You spray WD40 on your electronics?Spend more time drying your car than washing it. Any water left will rust your screws and fasteners and there goes your great looking chassis. Carefully warm air dry your hardware if you can. WD 40 is good to use. WD stands for Water. Displacement. Lots of people think WD 40. is just a lubricant but it's a lot more, in fact, you can buy WD. 40 with silicone oil in it. Protect your electronics from moisture, takes just a few extra minutes of care while you are cleaning. Preventative maintenance is important with RC cars.
Use this -I did some bashing on some loose gravel and it started raining. How do I clean the body and components? Tires? Undercarriage? Suspension?
Shut up and take all of my money. I need this. I don't have an air compressor at my condo, but have one at the farm. Where can I get one?
not directly on the electronicsYou spray WD40 on your electronics?
I am not a water guy no way. I use baby wipes which are cheap as, a brush and compressed air and my rigs come up beautifully every time..I did some bashing on some loose gravel and it started raining. How do I clean the body and components? Tires? Undercarriage? Suspension?
This is a 3d printed blower fan but you can also get ones on Amazon for really cheap. However a air compressor will perform way better then this. This works with a fan that just moves the air through a nozzle which makes it have a little bit of pressure. An aircompressor actually pumps air in a reservoir and pressurizes it.Shut up and take all of my money. I need this. I don't have an air compressor at my condo, but have one at the farm. Where can I get one?
Take your point, each to their own i guess. Air compressor is the way and a brush and silicon wd40 to finish. Still learning...Yet tons of us do it and have for many a years with great success...So strange..
Side note, I started some tests with nylon-6 filament, soaking them in wd40, water, oil and simple green to see any cause a noticeable difference. No idea how long it will take to see some sort of result. Stay tuned!
