Both halves? How do you stop it moving about then? The old halves screw together and have bearings at end, the old bearing is too smallYou unscrew the old one and replace both halves with this tube and nut. On the V4, push down the arm to expose the nut and clamp it and then unscrew the bottom (spring side).
Ignore my last comment, was having a thick moment. This picture explains it, thanks!
