How do I get this octagon thing out?
Brooksville, FL
  1. BigRock 4x4
  3. Nero
  4. Outcast 6s
I stripped my spur gear on my BRCC and I just ordered a new one but I can’t get this little octagon out... I tried using a small flat screwdriver and doing that but it started to cause damage to the octagon thing. Plz help
That’s a slipper pad. Pry it out with a small flat screwdriver.
you likely melted it, may not come out. Did you order the 4s one as a drop in heavy duty replacement?
The 4s spur? No I just bought a steel one for the 3s
That got the side with 2 of them out but the other 1 is still stuck in there. Should I just buy a new one? Or is there another way?
Is that still a metal/upgraded spur gear... I’ve stripped a few of these plastic ones and I want to upgrade it
That’s the steel version. The 4S has 4 pads too.
Will this bolt onto a Granite BLX 3s too? I’m new to the granite....
Yes the 4S slipper is a drop in replacement for the 3S line too. The Mega series can use it too, but the Mega will also need a Mod 0.8 pinion to match the spur.
Ok so the 4s slipper came in and I recommend it to anyone who is having problems with the 3s ones. It’s a direct fit into the 3s lines, makes the truck sound a lot beefier (at least on mine) and it’s completely metal so I shouldn’t have to mess with it for a while. They are expensive ($70ish) on eBay and hobby shops (that I looked at) but they are only around 30 on Jenny’s when she has them in stock.
Seeing as JENRC was all out of the Outcast 4s setup, I bought the Kraton 4s assembly which the exact same thing (as per Arrma exploded views).
