no1zeppelinfan
Want to change the front and rear diff oils (Done the centre) What do I undo to get to them? Is it just the screws highlighted? Thanks in advance
Just the top and bottom ones, not the center ones. Then you also need to remove the shock bottoms and the sway bar end links.Want to change the front and rear diff oils (Done the centre) What do I undo to get to them? Is it just the screws highlighted? Thanks in advanceView attachment 170896View attachment 170898
Cheers, I'll have a go laterJust the top and bottom ones, not the center ones. Then you also need to remove the shock bottoms and the sway bar end links.
The big white Lithium grease, thanks so muchThe lithium will be fine
Can I ask, "What is the Sway bar and what does it do"? also, car seems a lot louder, Think I've pushed the centre diff down to hard onto the main cog making it too tight? Someone said that's why it may seem a lot louder? Gonna check that in a bit.
Lol, Nah on the outside, Put proper diff fluids on the inside. So just the white grease on the outsides of the front and rear. I got loads of advice from here and there are some good youtube videos I did all that before starting.Did you put that grease inside the diffs? Or on the outside? I use that same white lithium grease on the outside of my diffs too, but your supposed to use silicone diff lube on the inside of the diffs. Like 50k in front, 200k center, and 20k rear. Or the weight of your preference. Everyone has a different preference on diff fluids.
Also, Always ask questions before doing something you’re not sure how to do is my best advice I’ve learned in the rc hobby and on this forum…. Also you can search YouTube or google for almost anything and find information. Use that to your advantage..
I didn't move the motor, none of the diagrams, video or anyone on here mentioned that. Think you are right, like mentioned above "think the mesh is too tight" With the grease I realised after I never put enough grease in anyway. So gonna do that again.Did you remove the motor before taking the center diff out? I'm not sure what you mean by this statement. The noise may be from an improper setting of the gear mesh between the pinion (gear on the motor) and spur (gear on the center diff).
Do keep in mind these rigs are plain noisy. Red n tacky vs lithium should not make an appreciable difference in noise. I'd just make sure there's no binding in the diffs and they are shimmed properly after you set the gear mesh between pinion and spur.
Red and Tacky is fine. But the noise you hear may not be grease related. Just me. Shimming may be the issue. It's trial and error. Nothing is perfect. But finding that good enough gear backlash is key. Drive it carefully and examine it well before sending it if that is how you want to fly.Thanks, It's all done now. Just seems noisier than before. The grease I used did seem thin? I'll check the grade of it later. Ordered some red and tacky, so may replace the front and rear. The advice on here has been invaluable.
Thanks for that, totally understand what you mean. Will take a pic and go on YouTube now as well. Hope to do it tomorrow. ThanksRed and Tacky is fine. But the noise you hear may not be grease related. Just me. Shimming may be the issue. It's trial and error. Nothing is perfect. But finding that good enough gear backlash is key. Drive it carefully and examine it well before sending it if that is how you want to fly.
EDITED:
Spur and pinion gear mesh is usually where bad noise comes from. Mesh it correctly. First thing is double check this before doing anything else. Understand that metal-metal spur and pinions do clatter. They have large Mod 1 teeth. Normal. If the mesh is too loose or too tight you will get a different sound. Both have differnt sounds to them. Too tight they whine. Too loose they tend to chatter. Hard to explain better. But with some experience,you can just look at the mesh and even hear when mesh is "Off". You can always send a pix of your gear mesh for us to see. Setting mesh is a "thing". Search for YT videos on this. Easiest to explain it better.
Just my ideas on this.
