I bought the Savox 1210 with a Racers Edge Glitch Buster. When I connect the new servo it won't power on? Do I need to reprogram the ESC? What inputs do each component hook into for the reciever?
You shouldn't have to do anything other than plug it in. Did you plug it in reversed? Is it plugged into the right channel? Also, don't bother with the glitch buster unless you discover issues after running your servo.I bought the Savox 1210 with a Racers Edge Glitch Buster. When I connect the new servo it won't power on? Do I need to reprogram the ESC? What inputs do each component hook into for the reciever?
You are using the stock Tactic radio? Should be servo = channel 1 , ESC = channel 2 if I remember correctly. Black wire is negative, make sure you are plugging them in the right polarity.What ports does everything get plugged into? ESC = B , servo = 1 ?
