Kraton How do I remove a stuck motor bearing?
BashTillBroken
Hospitality Award
Coming around to lap you AGAIN….. (Oregon)
  1. Granite Grom
  2. Infraction
  3. Kraton EXB
  4. Senton 3s
My Kratons motor bearing exploded and now is stuck and I tried the bread trick and it literary bent the cap where the bread was so I Viced it back into shape any ideas on how to get it unstuck or I’m stuck with buying myself a motor for my own birthday
Nobody has a toasted motor they can send the kid an end cap??
@jondilly1974 you are the motor slayer after all... no end caps?
I’ll send him a working motor if nobody else has just a cap...
Solution
I have changed motor bearings loads of times never had a problem. I just put it on a electric hob on full heat always just fell out
Torching it for a SHORT ! Time, then drop an ice cube, or Popcycle if you’ve got one on the bearing only, not on the plate, , should pop right out. I always carry dry ice & a torch into the mountains when crawling my 1/1 Jeep with 38” tires. Even if I don’t break, many others do gotta help each other! Heat is always the enemy…
