I feel stupid. How do you remove the outdrive cups from the diff? I looked all over on here and cant find how to remove them anywhere. Im replacing bearings and diff fluid...thanks guys
Thank youYou have to pull that gear off inside and the secret is beneath.
The gear isn't stuck on or anything but the diff fluid sometimes makes it stick on a little bit. Once you have it off there is a pin there that hold the drive cups. Not my favorite design....
Thank you
I'm about to do the same. Is this on 6s vehicles?
The easy way to remove sun gears
https://www.arrmaforum.com/threads/v3-diff-help-removing-sun-gear.7920/#post-77963
I'm still on the fence about shimming. Figured I'd run it first and see how it goes without. I always see differing opinions on the same vehicle for that. I think its more a matter of opinion than anything else at this point
