bigjoeymunoz619
Seem a bit small I haven’t ran them yet wondering if it’s going to Wind out quickly the difference is a 1” in height, thoughts and input would be appreciated
Those look like 2.8’s?? Are these trenchers ?Seem a bit small I haven’t ran them yet wondering if it’s going to Wind out quickly the difference is a 1” in height, thoughts and input would be appreciated
3.8 trenchers low profileThose look like 2.8’s?? Are these trenchers ?
I agree. The chassis slaps are pretty hard with stock suspension and LP tyres. I now use thicker shock oil and have lowered the spring collars. I change tyres depending on where I run the car:Will likely handle better, but land harder, especially on hard surfaces. I like the taller sidewall to add a bit of cushion considering how low my outcast and ERBEv2 sit to the ground. They land so hard!
With all these changes do you need to run any type of adapters or are all these hot swappable?I agree. The chassis slaps are pretty hard with stock suspension and LP tyres. I now use thicker shock oil and have lowered the spring collars. I change tyres depending on where I run the car:
- Backflips for skateparks and gravel pits,
- Backflip LPs for grass and dirt,
- Pro-Line Road Rages for on road,
- Pro-Line Shockwaves for anything and everything
No adapters needed for any of these wheels & tyres. They're all 17mm hex. The pre-mounted Pro-Line tyres I mentioned both have wheels with a 1/2" offset though, so the car sits a little widerWith all these changes do you need to run any type of adapters or are all these hot swappable?
Awesome thank for the info!No adapters needed for any of these wheels & tyres. They're all 17mm hex. The pre-mounted Pro-Line tyres I mentioned both have wheels with a 1/2" offset though, so the car sits a little wider
For the regular Backflips, I sometimes drop the pinion size by a tooth or two in hot weather but that's it
