Adamj804
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Outcast 4s
- Senton 6s
- Senton 3s
- Typhon 6s
- Typhon 3s
The foam simple green works noticeably better than the regular simple green spray.
The sealed bearing are "permanently lubricated" not supposed to be serviceable. However, they are also design for machinery in a relatively clean environment not RC cars. So plan to clean and or replace them as needed. It's a matter of time vs money. Eventually you will need to replace them.So is it good practice to rinse the 50/50 water and simple green off after spraying and scrubbing or is that not necessary? Sounds like some do, and some don’t reading some of these cleaning regimens line for line.
I assume the rubber shielded bearings come with grease in them, and once you start oiling that grease is spun out and you have to keep up with an oiling routine to keep them from seizing? Misguided or not, I have not been oiling them in the hope the rubber shield retains the grease, despite the fact I spray with simple green and hose the truck down (after removing the power and electronics modules).
Also What is recommended for greasing the differential external gears, under the covers?
Thanks!
You supposed to hit it flat out and watch is skip across the water.Rc car wash:
That's what I was trying to do. With the wide Trenchers it ALWAYS hydroplaned water. Know what's different? Weight from BLX185/TP4050 1700kv and not one but 2 3s batteries lolYou supposed to hit it flat out and watch is skip across the water.
My wife said that to me onceAnd it sucks. Way too small and inadequate.
Poor dude!My wife said that to me once
maybe its technique related,lolMy wife said that to me once
You don't need to clean your RC at 150 PSI. I think the blow gun is typically ~100 PSI max. Often 50-80 PSI is usually good for cleaning and it will help your tank last longer.What size air compressor would u guys recommend? I bought a 3 gal not knowing anything and it was harbor freights cheapest. And it sucks. Way too small and inadequate.
Thank You Jerold,You don't need to clean your RC at 150 PSI. I think the blow gun is typically ~100 PSI max. Often 50-80 PSI is usually good for cleaning and it will help your tank last longer.
Short answer
There is no "size" to an air compressor and the numbers can be deceiving. There are two numbers that matter, the size of the tank (gal) and the volumetric output of the compressor (SCFM). They work together.
Ignore HP numbers. It's either "maximum developed" or HP (Watts) used. The maximum developed is potential energy at maximum pressure. If they give you a HP number for the motor it just tells you how many Watts it uses. Both are BS marketing numbers.
I have an older Craftsman 6HP 30Gal compressor. The 6HP is the "maximum developed" meaning that when the tank is full @150 PSI that somehow equates to 6HP of energy for a microsecond. It's not usable for any length of time, so I don't care.
However, it works well for everything I do. This would be the closet thing now
https://www.lowes.com/pd/CRAFTSMAN-...73698660ae4519cdcd30e55785afa2d1&gclsrc=3p.ds
I don't think you need something this big just to blow out an RC and it's a bit expensive, but you get what you pay for. I think I paid like $400, 20 years ago and I've gotten at least twice the value from it. If you buy a good one you will keep it for ever. Avoid off brands or the cost optimize products. There can be some deals on Craig's list too.
Longer Answer
There are two numbers that you'll need to understand the size of the tank (30 Gal) and the volumetric output of the compressor in Standard Cubic Feet Per Minute (SCFM). It seems to be standard for xx.x SCFM @ 90psi to be listed.
The tank is a measure of how long you can use it before the compressor turns on again. The tank is a buffer for the already compressed air. However, once you pull the trigger to release air the pressure goes down and you still have 30 Gals of air just at a lower pressure. The compressor will turn on at a lower pressure. With this cycle the tank pressure is maintained in a range like 100-150psi.
There are application charts for air tools, where they specify the PSI and SCFM required. An air nozzle for cleaning is an open valve and you need to "refill" (increase pressure) your tank quickly. To do that you need the compressor to output a high volume of air, which is SCFM, meaning how much air, can an air compressor compress at a particular pressure. The bigger the SCFM the more air you can use.
It's a game of how fast can your compressor replace the air you're using and right now your using air faster than it's compressed. You could just get a bigger tank but the compressor will run longer and it will solve a short term problem. You can have have high SCFM with a small tank and it will suck, or a large tank with low SCFM and it will suck. Both numbers need to be solid.
I've done that a few times in winter does a good job as long as you dry it of when you get home and spray with wd40. not good for your tyre foams though unless they are sealedRc car wash:
Not good for the bearings eitherI've done that a few times in winter does a good job as long as you dry it of when you get home and spray with wd40. not good for your tyre foams though unless they are sealed
not good for anything really but if you run in winter you get sick of cleaning them all the time its a good way to get most of the muck off I supposeNot good for the bearings either
Am I a neglectful rc parent? An air hose is all my rigs get, unless brokenDish soap and water with a paint brush and a soft scrub brush for the tires. Rinse, dry, and lube.
