How do you clean your RC?
Mongoose
Likes
94
Kraton, 4x4-Mega
Thank you. To be fair though, I haven't gotten real dirty....but I clean it like this after every run.
chevys10zr2003
ArrmaForum Fan
Likes
500
Minnesota, USA
Kraton, Senton, Typhon
So what is everyone using to clean silicone shock oil and diff oils off of everything? I have tried using 50/50 Simple Green but there was still oil left on the shock and diff components after they dried. Is there something else that would work better for removing it or do I just need to use Simple Green full strength?
Mr.Duke
Likes
484
NC
Outcast
I put my metal diff interns into a shallow glass jar and soak with Brakleen then wipe them down with paper towels. To get all the residual diff oil from in between the gear teeth I mesh two similar gears together with a paper towel sandwiched in between the two gears
chevys10zr2003
ArrmaForum Fan
Likes
500
Minnesota, USA
Thanks you two. I guess I have to go and get brake cleaner now. I guess I was just trying to use something I already had but no big deal.
slick2500
ArrmaForum Fan
Likes
847
Rapid City, SD
Outcast
Get yourself one of these things if you look around on eBay you can find them for .99 cents https://www.stashtea.com/products/c...iz_bt8Vm_rbdhJtFBuYem8R09mmT1p7kaAgRNEALw_wcB
Buy some Naphtha, my local hardware store carries this https://www.ruralking.com/vm-p-naph...IJZG7hLKixC1jfcQ2lGSTOMydlotRj54aAt0_EALw_wcB
Put the diff parts in the tea infuser, put some Naphtha in a jar, swish the tea infuser around in the jar, most if not all of the diff oil will come off.
chevys10zr2003
ArrmaForum Fan
Likes
500
Minnesota, USA
That would be awesome for the diff parts but I don't know if the shock bodies would fit in the tea infuser. I can always just put everything in a Mason jar and shake it for a minute too since I have a bunch of those and could spare one to keep for my rc duty. Thanks @slick2500!
slick2500
ArrmaForum Fan
Likes
847
Rapid City, SD
Outcast
I saw a guy do this in a video with his diffs and the gears came out so clean, I cannot for the life of me find the video though.
Jerry-rigged
ArrmaForum Fan
Likes
1,308
Texas, Baby!
Kraton, Typhon, 4x4-Mega
After almost killing the wife's roses with brake cleaner overspray while cleaning bearings, I started spraying the bearings so the overspray goes into a Gatorade bottle. Then for diff gear cleaning, I drop them into the bottle, shake it around for a bit, let them soak, shake, repeat for a while. they come out very clean.
Similar threads
