EAGLELITE
How do you access the diff? Seems a little different than most. Can anyone help me out how to do this procedure. I'm a little apprehensive about doing it....thanks.
I am on the verge of a bearing swap and was wondering about the same thing. So pretty much just need to take car apart. My next question is what lube/grease on dif gears cause if I tearing apart might as well clean and lube. I think I had read somewhere before using pb blast garage door lubeYep. Remove the suspension, servo, and ESC then split the chassis.
I just posted how to access the diff on the voltage here if you want to read some of my notes: https://www.arrmaforum.com/threads/granite-trouble.7414/post-250271I am on the verge of a bearing swap and was wondering about the same thing. So pretty much just need to take car apart. My next question is what lube/grease on dif gears cause if I tearing apart might as well clean and lube. I think I had read somewhere before using pb blast garage door lube
