Mojave man
- Mojave
- Senton 6s
I just want to know how you guys do it so I can learn some things. I know how I clean my arrma’s but I just want to learn some more/better techniques.
Yep exactly what I do. Now I can feel more confident that what I’m doing is right!I use this to put some cleaner on it (cost £0.69)
then I fill up the bottle with water and wash it down, next I use an air blower to dry it off https://www.amazon.co.uk/Merry-ELECTRIC-BLOWER-DRIER-100761/dp/B00BKXW6S0/ and finally touch all area of relevancy with WD40 - after its been a while I lubricate the relevant parts, pivot balls, bearings etc everything that could attract rust or needs to move freely
That's where a steam cleaner comes in. Just don't get a cheap one they spit more water then anything.Pretty much the same as above (no steam cleaner). I use simple green, let it set for a few minutes and spray it offwith water and a soapy brush. Spray it again with wd40, blow it off with some air and then hit a few areas with some silicone spray. I’m not too fussy so all this takes just a few minutes.
Then If you search around on here there’s a multi page subject with some good ideas. My biggest problem this time of year is the outside hose is away to keep it from freezing. Slop sink is not big enough.
I just buy a new truck every time mine gets dirty. Just kidding. It depends on how bad it is. If I'm ripping in a construction site, I'll put the truck on a wooden block, set the radio to have the wheels spinning at 1/4 speed, then lightly rinse with a garden hose being careful to stay away from the electronics. If it's after a bash in snow, I just lightly rinse it in a laundry sink, still being careful to avoid electronics. After washing, I try to blow it off with my compressor, than hang it upside down for a day or so to let it drip dry. A quick shot with silicone spray in some of the areas like around bearings, steering components and axles to make sure nothing rusts. Or I can just buy a new one.I just want to know how you guys do it so I can learn some things. I know how I clean my arrma’s but I just want to learn some more/better techniques.
