RC BOY
I've heard lot of peoples threads and they say that the senton 6s blx does not have. How do you put one in and where do you get them.
thanks for the info !Hi,
You need the kit sway bar;
Front:
Rear;
and don't overtight the little cover screws;
Not the same truck on track, especially on inside SCTE track....
PL
The sway bars are the same across all models so they will fit perfectly. The shorter bar is for the front & longer for the rear.thanks for the info !
Do you know if the outcast/notorious kit fits?
Everything is the same. As a matter of fact, all the parts in that link will fit on all models as well. When it come to Arrma 6s flat chassis cars, about 70% of parts are made for all cars. That's why it's so easy to own multiple cars.does this fit ? i know the sway bar itself is the same. but what about all the other supporting pieces that i need?
https://www.ebay.com/itm/2018-Arrma...on-A-Arm-Hinge-Pin-Sway-Bar-Set-/122928364358
Yeah, the part numbers are different for the front & rear bars since they are different sizes.awesome. thats good news.
i was confused because as per PL9171's reply...the part numbers were different.
Ok i will go ahead and order those parts for my senton !
I used the Typhon 6s sway bars for my V3 Senton 6s , I have it set up for street , not dirt , have Hoons on it . Great handling street truck now !!!!!!!
I can't find anything for 3S,.. I just see 6S
I don't think they have sway bars for the 3s rigs ?
