Outcast how do you remove rear input gear?
It gives a teardown in the book you got when you bought your truck. It's actually pretty easy, and I would bet that youtube has some videos on it.
I swear I responded to this thread.
You have to remove the diff.
Then remove the out drive cup from the pinion shaft, the thing that the center driveshaft connects to, then you can pull the gear and shaft out of the bulkhead. From there you remove the gear and reinstall.
