Per subject, how do you set the steering end points on a Spektrum DX3 radio? Horizon Hobby replaced my terrible STX2 and I want to set the steering end points but the process in the DX3 manual is confusing. Has anyone successfully done it?
I too have been struggling with this. My outcast 8s steers further to the left than to the right. I put in a tactic system that I had laying around and problem solved.Per subject, how do you set the steering end points on a Spektrum DX3 radio? Horizon Hobby replaced my terrible STX2 and I want to set the steering end points but the process in the DX3 manual is confusing. Has anyone successfully done it?
Thanks! For some reason this sounds simpler (less confusing) than what I read in the manual...but it is probably the same and I'm just looking at it with rested eyes.I did it on my Infraction V2s and it wasn’t too bad. The instructions aren’t too bad and pretty straightforward. Put the transmitter in adjustment mode (blue LED), turn full left and adjust the steering rate knob till you reach the endpoint of travel. Then turn full right and do the same.
Thanks, I just spent 2 hours trying to figure this out on my Losi Lasernut. The instructions I was given in the manual make absolutely no sense. Those instructions were straight forward. Thank you!I did it on my Infraction V2s and it wasn’t too bad. The instructions aren’t too bad and pretty straightforward. Put the transmitter in adjustment mode (blue LED), turn full left and adjust the steering rate knob till you reach the endpoint of travel. Then turn full right and do the same.
