lostcoastwizard
This is from a typhon 3s, its a 57t spur gear. It's only half worn. When I took it off, the pinion gear moved up and a down a little. The little screw was loose. I'm pretty sure that's why it's like that. But now that I got a replacement spur gear, put a little blue lock tight on the screw, it sounds all tight and clicky when I pull the throttle. Is the default pinion gear too big? Is the spur gear not good? Is there some simple trick to putting the thing back together that I don't understand?
