How full is full
oldgoat
I’m going over the Vorteks and doing things I’ve learned on hear to try to prevent problems. I opened up my diffs to check and not much oil in them. My question is how full do I make them?
It does expand a bit when it gets hot, I usually leave a few mm of space at the top so it doesn’t ooze out past the o-rings when it expands. Or as @dure16 said, just over the top cross pins.
Agree just over the top of the cross pin. Try not to get any diff fluid in the 4 screw holes that mount the gear back on. It will create pressure and blow out the back of the diff case.
