MrTitanium
Speak softly and carry a big stick.
- BigRock
- BigRock 4x4
- Granite Grom
- Kraton EXB
- Nero
- Infraction 4x4
All depends what you plan to use it for. If you’re going to bash it hard, get the HR Gold springs.Bought the traxxas fixes now im debating if i get the hobao retainers. I would like to make everything gun metal red but that will cost me an arm
“The toilet of canada”
Seeing as you bought it used, I would strongly recommend that you:
- Take apart the three diffs, inspect them and then add Lucas Red & Tacky grease.
- Check the bearings. Hell… just buy a new set.
- Check the driveshaft boots as they tear easily.
- Make sure the slipper isn’t glazed. Replace if necessary.
- Install a shim under the steering servo saver to get more tension. Adjust as necessary.
Et voila! Let me know if you need help.
