It's hard to even tell mesh by picture. It's more about feel and sound to me.Pictures please.
Doing mesh takes practice. I've done a few plastic spurs getting it right. Thought I had stripped one just now landing a backflip under full throttle but nope, rear diff instead I keep a couple of spare fully assembled diffs handy. They are easy to replace.
Metal spurs aren't any better.Also, plastic spurs are sometimes not perfectly concentric and you may have a high spot - so be sure to test the mesh in several areas.
Naw man it’s very subtle… I click real slow like though each tooth and ANY SLIGHTLY rough points I use 800 grit sand paper folded tight to sand between the teeth…constantly double checking so I don’t take off too much. I will go over the entire spur and also the pinion and the result is very smooth action.Really That's dangerous and something I haven't found yet. Maybe the pinion will just wear it down until it's perfectly round
This takes time but I think is worth it.
I apologizePictures please.
. It seems to have not uploaded the video . An I'm not to tech savvy so bare with me.My crystal is a little foggy as I can't see ur mesh lol
I won't allow me to upload a videoIt's hard to even tell mesh by picture. It's more about feel and sound to me.
It’s overkill of course. But It calms me down to zero in on something like that. So I just go with it.I don't have that level of patience. If the mesh looks and sounds right with a few clicks I'll leave it at that. My original spur stripping was down to lack of experience more than inconsistencies in spur quality.
Totally bro. I'm getting a lot more involved in wrenching than I ever thought I would. And a good mesh is worth taking time over.It’s overkill of course. But It calms me down to zero in on something like that. So I just go with it.
I just eye it and then go by feel mostly and check it all the way around many times slowly tooth by tooth. Even taking 1000 grit sandpaper to parts of the spur and make sure everything is even and smooth.I use the paper method if I'm struggling to get my mesh tight enough (but not too tight). I've seen KT use that method and then SEND IT TO THE MOON so it must be legit.
